跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
MacOS will not start
I have a new SSD installed and working in this computer. But MacOS wont’t show the installation screen because its grayed out.
I have tried to zap the PRAM, replace the backup battery, tried to boot from USB and Internet recovery, removed the RAM... everything.
Anyone got a clue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The drive needs to be formatted with the correct format. Using your external drive to boot up with run Disk Utility and format the drive with GUID and a Journaled volume. Then you can install the OS.
这个答案有帮助吗?
得分 2
6条评论:
I am a little bit more pro than that (thanks for the answer though). The problem is that the computer do not continue to disk utility.
完成的
OK, then lets get more details here as clearly something is a mis. Who's SSD (make & model) are you using and which port are you connecting to HD, optical drive or the spare and lastly, what is your MacOS.
Also can you post a screen shot of the Disk Utility screen 在已经存在的问题里加入图片
完成的
@danj Is an Apple system update going to try to mess with the GUID format on this SSD?
完成的
@mayer - Yes! High Sierra will automagically update the drives partition from GUID/Journaled to GUID/APFS! This can be an issue if the person is trying to install an older OS onto the drive after its been setup with High Sierra.
If you are talking about service updates (not upgrading) they won't change anything.
完成的
There is a new TR200 drive from Toshiba, the original Apple SSD have the same problem, gray screen when booting.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
peter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 140
