跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 5S vs 7 in battery performance. 7 sucks, why?
So I've decided to buy an iPhone 7, it's on iOS 11.3.1 (DFU Restored)
My iPhone 5S is on iOS 8.4
Battery Stats:
iPhone 7: 303 Cycles, 12% wear, apparently from Battery Info Beta
iPhone 5S: 277 Cycles
I charge them both up to 100%, below's the results.
iPhone 7 lasts 40 hours standby.
iPhone 5S is 80+ hours standby, I had to use it, though had 24% left.
So what's going on here..? Where's Apple's 10+ days Standby claim? Really tempted to resell because of this..
Usage times iPhone 5S wins by 15-20%.
iPhone 7 lasts 4 hours.
iPhone 5S lasts 5.
Why is iPhone 7 battery so bad?
Please forgive frustration.. but this is quite ridiculous to see an iPhone 7 claiming better battery efficiency, only to die twice as quick.
What can be done to fix it, or make it more efficient?
I've tried turning off background app refresh, email push, bluetooth, etc.. soon to get a battery replacement, though if standby times are this crap.. what's the point? Could a battery replacement truly help this issue? (It is after-all 2 years old)
Looking for a scientific answer here somewhat..
Thinking I should resell and get a 7+ instead.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the iPhone 7 is on 11.4 there is a bug with 5GHz wifi that causes fast battery drain so try using 2.4GHz wifi.
Also the battery life feature in iOS has a different percentage reading than compared from 3Utools so check the battery health via 3Utools too.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sumona Florence 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 141
