跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
387 个问题 查看全部
Trying to make a custom ps4 case
Ive seen a few videos on youtube of custom ps4 cases. I don't really wanna take apart my ps4 pro, and im not wanting to go out and spend a few hundred on a new or used pro. I saw that ifixit sells the motherboard >>>> PlayStation 4 Pro (CUH-70xx) Motherboard <<<<
and was wondering if that would work, and if it did work what other important thing would I need to make it work like a ps4
Thanks so much!!
PlayStation 4 Pro (CUH-70xx) Motherboard图片
产品
$199.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sure, that would work. You'd also need the disc drive, power supply, hard drive, heat sink and fan. These components are made to fit perfectly inside the PS4 case and there is basically no room to move them or rearrange them. If you had some custom ribbon cables and other cables made you could to that but it would be difficult. Custom cases for these are very hard to make because PS4's are made to fit perfectly together with no room for moving anything.
Hope this helps.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Caleb P. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 2,150
