跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone won’t start with new screen but works with the old broke one
My friend came in and had me to change his ip 7 screen which wos totally broken . So I changed the screen and everything went great but when I tried to start it the phone didnot startup it started as long until the Apple logo showed up. So I checked all connectors and everything and still the same issue. Then I thought lucky me I have one more spare screen so I decided to try that one and same issue once again. Well I now tried the old broken screen and suddenly the phone booted up.
The phones home button doesn’t work neither did the proximity sensor but howecome it started up with the old broken screen and not with the 2 new ones?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I do agree with Jacob's answer, you can try to figure it out if you have free time.
said the two new lcds are defectived is impossible.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Is your friend running the latest version of iOS? I believe a while back Apple released an update so that third-party displays would not work with an iPhone. However, newer iOS updates allow one to use a third-party display. If the phone is not running iOS 11.4, try to update it and see what happens.
这个答案有帮助吗?
得分 1
添加一条评论
sounds like a defective screen.
as long as you disconnected the battery before the repair you should be good.
try a new screen as home button connects to lcd and could also be defective/not working:)
这个答案有帮助吗?
得分 0
1条评论:
Sry both screens worked
完成的
添加一条评论
添加你的答案
Kristian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
