跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE will only turn on when plugged into outlet, does not respond
When plugged into outlet, will show the plug into iTunes screen. The second I unplug it, it dies. Battery doesn't seem to hold a charge (I just put in a new one).
When plugged into a computer (both MacBook and iMac), phone will not turn on, cannot get to the iTunes plug in screen or Apple logo. I can put it into DFU mode but then gets stuck on "Waiting for iPhone" status in iTunes.
Any thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like the logic board might damaged, but it's hard to suggest anything without any info on iphone's history. Not to let anything untried you could try replace the lightning connector..data/power flow through it on the way to itunes and power ICs and since it's an inexpensive part it would be good to rule it out as a possible faulty component. An inspection of the relevant connector on the logic board would be needed too.
这个答案有帮助吗?
得分 3
1条评论:
Going to get a new lightning connector and test it out. Will report back!
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 67
