跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s No Image (no water damage) Display completely Black
Hi Guys..
I m here again for expert advises and for learn reparing :)
My client sent me iphone 6s wth no image.
The phone is second hand, so they dont tell me anything about phone history.
I check with new display but the screen remain black, itunes recognize phone.
I search on web and found this video
https://www.youtube.com/watch?v=dYbW35dl...
Try to putout C4200.
fortunately the first component (c4200) is shortage and i solve the problem.
Obviously you are thinking, if everything is ok, why i m here, :)))
I m here because i want to learn and understand how find the problem on the phone and not just solve the problem searching in net or putting out every component.
My question is :
In this case, which is the first step.
Before searching on the web i check if the backlight is present,
i check all backlight filter, check FPC connector if damage.
MY proper question is this line DISPLAY POWER PP5V7_LCM_AVDDH must have 5 volt???
so i check a phone who run perfectly (without lcd / touch panel)
If there is no problem in the phone, i find 5 volt here (c4200)?
Which is the right way to proceed in this case, if i have only schematic and not INTERNET :) Thanks a lot for attention.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@refectio Sir.. do you have some suggestion plz := ??
完成的
@refectio what do you think? It's my understanding that PP5V7_LCM_AVDDH does have (needs) 5.7V and C4200 should show 5V. Would you start with Chestnut and work toward the end of the circuit at the connector? Of course I may be way off with my schematic :-)
完成的
添加一条评论
1个答案
最有帮助的答案
Being a 6s, I agree... first checking phone boots and connects to itunes... is drawing proper current with DCPS or just check Ameter. Then Disconnecting battery and then screen, I check the FPC pins in Diode mode. In most display cases and backlight.. this will help guide you to the right location for repair.
The 1v8, 5.7 and -5.7 lines must be there as well as several other voltages but starting with Diode mode measurements against the ZXW Seat resistance chart really helps speed things up most of the time :)
这个答案有帮助吗?
得分 2
1条评论:
Thanks a lot both of you guys :)
完成的
添加一条评论
添加你的答案
AGS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,732
