跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
639 个问题 查看全部
The LCD screen has no backlight and no image
A few days ago, I spilled some water right onto the front panel of my switch. I let it dry for a few days and tried to turn it on, and assumed the worst when I didn't see anything on the screen. However, I found out that the console functions perfectly while docked, which leads me to believe the water only damaged the LCD screen. I just want to make sure I'm correct in assuming this before I pull the trigger and buy a replacement LCD. Could there be something else that's causing the issue I'm having?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
It's most likely the LCD ribbon cable right where it goes into the connector. Many times it will get corroded right there. It's entirely possible that multiple other things are wrong as well but you won't know until you take it apart. If I were you I'd pop off the back panel and metal plate and just take a look at the motherboard to see what seems to be affected the most. In fact if it was me I would remove the motherboard and clean it, then put it back in and clean any connectors and ribbon cables that need it and see if it will work...sometimes that's all it takes.
这个答案有帮助吗?
得分 2
1条评论:
I absolutely love when TronicsFix answers questions! TronicsFix and Andrew Paul are by far the most helpful technicians on YouTube today!!!!!!!!! Everyone else is purely a waist of time!!!!!!
完成的
添加一条评论
Jessica Jones is also absolutely fantastic on YouTube!!!
这个答案有帮助吗?
得分 0
1条评论:
Did this end up helping? I just got a deal on a switch on ebay and the seller said the screen works normally sometimes, but other times you can see the image bit theres no backlight. I dont know if if replacing the screen would fix it or if i should try replacing the backlight connector first.
完成的
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 104
总计 6,182
