跳转到主内容
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 个问题 查看全部
Keyboard and Mouse randomly cut out and stop working.
The built-in trackpad and keyboard randomly cut out and stop working every time, when the actual mac os operating system loaded. I get a message that I need to use a bluetooth keyboard.
I have formatted the entire ssd and now I am able to login most of the time, but after login the keyboard and mouse cut out and I am no longer able to use it. I have booted into safe mode and the trackpad and keyboard don't even work in login. I have also tried all the SMC, PRAM and ran apples diagnostics which don't display any hardware errors.
Are there any solutions to fixing this issue as the mac no longer has warranty?
Many thanks
Jon
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Apple may fix it for you for free:
Keyboard Service Program for MacBook and MacBook Pro
https://www.apple.com/support/keyboard-s...
这个答案有帮助吗?
得分 2
添加一条评论
Because of the way the trackpad handles the signals (it takes the keyboard signals and daisy chains through itself to the mobo) you most likely need to replace the trackpad itself and you should restore functionality. Does your power button still work?
这个答案有帮助吗?
得分 1
添加一条评论
I’ve the same problem (many years later). The keyboard ánd trackpad stopped working at the same time. Nothing seems to work (like PRAM and SMC reset). External mouse and keyboard works fine though.
I’ll try to replace the trackpad flex cable. And I hope it will do the trick. Apple says I should replace the top case. But I’m not sure why that would solve the problem.
Edit: I replaced the trackpad (with the original cable), that worked! Both keyboard and trackpad work fine now!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rs Graphics 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 155
