跳转到主内容
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 个问题 查看全部
How can I get the back piece of the Ipad (5th Generation)
I bought a case and it had a sticky thing that kept the Ipad in place. I took it off because after 1 year of use the iPad wasn’t sticking to the case. When I removed the case the sticky things was on the back of my Ipad and wouldn't come off. I need the back piece if the Ipad.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I guess what's left on the back of your housing is some kind of adhesive that might be removed one way or the other. Some adhesives are water based, others solvent based..depending on the solvent it might be melted by alcohol, isopropyl alcohol, turpentine or the likes. You might be better off trying various solvents until you cross the right one, less expensive and time consuming, replacing the housing takes hours let alone the risk of damaging something in the process. A mild heat could help in the task.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Jai Kamparachad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 73
