跳转到主内容
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
Why is my brush roll and indicator not working?
My indicator light stays off and the brush roll doesn't function. I removed the roll and disassembled it. No blockages, everything clean, wires are good, position switch working properly. Performed wiring checks, beyond possible high resistance through the circuit board no issues noted. Can find no information on how much voltage should be being supplied to the brush roll. Or what proper resistance readings should be. Checked voltage at where the brush roll connects to the base. Vacuum on 7V with or without pressing the latch switch to imitate the bottom being connected unsure what proper voltage should be.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
Remember, the handle must be pulled back for the roller brush to turn on AND the switch must be set to carpet or the 2nd position on the switch. Green light should come on.
这个答案有帮助吗?
得分 1
添加一条评论
Remember, the handle must be pulled back for the roller brush to turn on AND the power switch must be set to carpet. The green light should turn on.
这个答案有帮助吗?
得分 1
添加一条评论
Hi there ,
I recommend calling the manufacturer for support as they have their engineers who designed them and who can help you on the phone line
这个答案有帮助吗?
得分 0
1条评论:
Roller not turning,no green light checked no plugs,filters ok
完成的
添加一条评论
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
I'm having the exact issue its in the right position and leaned back it moves forward just a tiny bit that's it.Microswitch is good the 2 belts are also good There is a brush roller motor and another motor behind the hepa filter.i will use this on floor mode until I purchase a new sweeper and trust me it will not be another shark.They do not make parts for the duoclean liftaway so it makes it hard to repair
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
devstamant 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 37
过去 30 天: 289
总计 16,205
