跳转到主内容
Repair and disassembly guides for GE Microwave ovens.
349 个问题 查看全部
Replacing dead high voltage cap with similar of lower capacitance.
Hi,
The high voltage capacitor for my microwave oven has shorted. It is a 2100v, 86mfd capacitor.
I have a "spare" that is very similar: 2100v .76 mfd (so .76 instead of .86 mfd. Can I use it?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Without knowing more, I'd say not to use it. That particular rating may be required for the proper operation of the magnetron (the thing that generates the microwaves). GE should be able to get you the right part.
Best of luck.
这个答案有帮助吗?
得分 0
1条评论:
I had been hoping for an informed reply. It turns out, as I learned since I posted the question, that the high voltage capacitor is part o fhe voltage doubling circuit between the high voltage transformer and the magnetron. If the capacitance is a bit low, it reduces the final voltage - it does not quite "double" - to the magnetron, which results in a small reduction in the power the magnetron delivers, but with zero risk to the circuitry.
完成的
添加一条评论
添加你的答案
H Stahl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 138
