跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Stuck in Bootloop before and after replacing battery
With my 6s+ the battery went from 90% to 1% and restarted itself over and over, and then wouldn't charge. I thought the battery was to blame so I replaced it. It worked good for a day and then its back to 1% and restarting. Now, its stuck in a boot loop were it will go between quickly flashing the backlight and flashing apple logo. Any ideas? Ive tried to restore but it doesn't stay on long enough.
Also, when I first opened the phone 6 months after buying it on eBay, the battery connector cover was missing. I read online it could be the battery sensor. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try applying some pressure down on the connector while the phone turns on. If it works fine then you just need the metal bracket. If not then you might be missing some components near the battery connector which are commonly knocked off when preforming a battery replacement.
这个答案有帮助吗?
得分 1
1条评论:
Thanks! Im going to have it replaced sometime this week.
完成的
添加一条评论
最有帮助的答案
I think you need the battery connector cover, the battery ribbon cable plug may have a loose connection to the battery connector on the board requiring that metal cover that goes over the battery connector and charging port connector.
iFixit sells the battery connector bracket here:
iPhone 6s Plus Battery Connector Bracket
Here is a guide in case you need it:
iPhone 6s Plus 电池更换
Fix a loose connection causing charging and connectivity problems by replacing a bent or missing metal bracket securing the battery connector and lightning port assembly connector to the logic board. This part is compatible with an iPhone 6s Plus.图片
产品
$6.99
这个答案有帮助吗?
得分 2
2条评论:
Would this really solve my problem? Ive snapped both connects in tight and it still wont work.
完成的
If you have tried turning it on while applying pressure to the connection then it won't work.
完成的
添加一条评论
添加你的答案
Michael N 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 254
