跳转到主内容
加入维修社区 - 创建账户
Logitech 于 2013 年发布的便携式无线扬声器。
Why won't my speaker charge?
I plugged in the speaker to charge it, but the charging light won’t turn on and the speaker won’t charge. I also think some water got into the port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
So there is a couple of possible issues here. Try the following then reply to me.
1. Plug in the charger and move it a little, Be careful. Is there any movement when you try to move the cord around in the port?
2. Are you using a known working OEM charger for this item?
3. It is possible that the water got on Caps and other components on the motherboard. This will require a special set of skills to repair.
4. Did it work right before it had exposure to water?
由完成的
1. Tried that,nothing.
2. I am using the same one that came with the speaker.
3. I think some water got into the place were the charger is supposed to go in.
4.yes it worked just fine
Thanks for your answer
由完成的
添加一条评论
1个答案
If your UE Boom speaker does not charge, see the UE Boom Won’t Charge or Loses Battery Quickly problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yasmin Dallol 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 28
总计 5,220
