跳转到主内容
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
164 个问题 查看全部
8 beeps. Screen won't turn on on alienware 15
i had my alienware 15 for 2 years, then i disassembly to clean the fan and i pulled the 30 pin connector and i broke a part in the side, that part connects the soket and the motherbase
i turned up the pc and then the black screen and the 8 beeps appears,
i dont know if that have a solution because i dont know if that socket can be replazed and solded to the motherboard or i need to buy a new one.
one time that i turned on the pc the alienware logo showed up but then i turned off and never came back
pls help i dont know what to do, a new motherboard cost like $650 :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
'''++Rodrigo L++'''
“i broke a part in the side “ yes that could be your problem. Here is the bad part. Unless we can see the damage the board etc. there is not a whole lot we can do. So, take some good pictures and post those with your question. Use this guide 在已经存在的问题里加入图片 for that. It will allow us to see what you see. If it is broken off there may still be the possibility to attach it “properly” by soldering it on etc.
这个答案有帮助吗?
得分 2
2条评论:
I connected my aw to the television and then it worked but I disassembled it again and I realized that the edp connector was totally ripped off, thats because i sended to a verifyed dell center and the man there robbed me a 4 gb ram card and the half of the screwls, so i think he tried to repair my connector and he ripped of or i dont know, but now i dont have any more that connector. so i search and i dont find one, i dont know if i can replace him.
the computer works in a external monitor but the gpu dosnt work in that.
so i need to replace that connector.
if someone know where i can find a replacement pls tell me
thanks
完成的
Rodrigo L we need all the numbers that are on the motherboard so we can at least try to find what you need. Also, post some pictures so we can see the damage.
完成的
添加一条评论
添加你的答案
Rodrigo L 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 214
