跳转到主内容
A problem with update to high sierra
I have a mackbook pro 13 inch made in 2011 late. I replace the hard drive with samsung SSD EVO 860 1TB recently.
the laptop still running on mac os EI Captain, so I‘m wondering that it possible to update system from EI Captain to High sierra, because I found someone said Apple has some issues still with the new APFS file system running on SATA based SSD systems
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
I would suggest backing up your files and performing a manual clean install.
You can use disk utility to partition the new Samsung to journaled instead of APFS and then installing high sierra.
If you upgrade, stubbornly OS X will be converted to APFS, but on a manual clean install the conversion does not occur.
这个答案有帮助吗?
得分 2
2条评论:
is there any solution that can just upgrade to high sierra directly, because I have lots of software on EI captain right now, I don't want to install all the softwares again.
完成的
Actually, try this terminal command. It assumes you have downloaded High Sierra Installer already. If the download runs the installer, simply CMD+Q to quit the installer. Then open a Terminal and type the following:
[code]/Applications/Install\ macOS\ High\ Sierra.app/Contents/Resources/startosinstall --converttoapfs NO[code]
完成的
添加一条评论
添加你的答案
owen L 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 17
总计 469
