跳转到主内容
加入维修社区 - 创建账户
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Why won't my MacBook Pro charge?
The charger light comes on periodically and charges but now it won't. I had to move it around and by luck it would get it just right to charge. Do the magnetic pins wear down in the charger or the laptop?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
It could be the pins on your charger if it it the original. I have the same issue with my older MacBook Pro(2009). You could try replacing the DC in board, or using a newer charger if it really bothers you.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your reply. I tried a different charger and it works much better. I like the video and since it is an older laptop I will probably need the video in the near future.
完成的
添加一条评论
the pins don't wear down, but the springs. as you have to move the coil around, it could also be a break in the cable itself, usually the plus cable. try a different charger, check for differences. post.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your response. I changed power cords and it is working now. The old cord finally did not charge at all.
完成的
添加一条评论
添加你的答案
Peggy Ohms 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 148
