I have Maytag MFI2568AES Display has Gone Blank
MY display is blank and no water or ice dispensing. no problem with cooling thats is working great. PLease help what can I do to fix that issue ?
thank you
Usually after a power outage your refrigerator will reset itself. The fridge and freezer section should be working just fine after the power outage. The only issue is the digital display panel will not be lit. Some refrigerators may not begin cooling again and the reset needs to be done once power is restored. We have seen many people having all the food in the refrigerator and freezer going bad as the power was out for many many hours.
If after a power outage, your refrigerator is cooling or not cooling, you will usually need to reset the front display panel. This is to get the panel working again and also to get the refrigerator to begin cooling again if applicable. All the below methods and conditions for reset will vary depending on the make and model of your refrigerator.
This link may show you how to reset yours:
https://removeandreplace.com/2016/02/02/...
UPDATE
What is Sabbath Mode?
Sabbath Mode is designed for the traveler or for those whose religious observances require turning off the lights. By selecting this feature, the temperature set points remain unchanged, but the control panel lights, interior lights, and control audio turn off. For most efficient operation, it is recommended to exit the Sabbath Mode when it is no longer required.
Press and hold SABBATH for 3 seconds to turn on the feature. After the 3-second countdown, the feature will activate and all other displays will turn Off.
Press and hold SABBATH for 3 seconds to turn off the feature and turn on the display.
这个答案有帮助吗?
tried every step and the screen is still blank no lights. Fridge cooling great no issues there. need help.
Check and see if the unit is in sabbath mode.
Did you resolve this problem. I am having same issue. Cools but display will not function. No buttons work. Temp still shows and is at factory settings. And I see no sabbath button. FYI.
Where the heck is the "Sabbath" button?
What is the model number of the refrigerator?
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 54
总计 38,417
