跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
Will not load cmos
My laptop will not complete the cmos load
it stops a part way thru the process
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have the laptop with a friend right now and so cannot suppy the complete series number. However I went on line and found hat that this particular series of Toshiba laptop does not have a CMOS battery but the operating battery is used to boot up the CMOS.
完成的
添加一条评论
1个答案
You may have a bad CMOS battery. Test it, and replace it if you aren't sure it is good.
这个答案有帮助吗?
得分 0
6条评论:
The computer does not have a cmos battery The laptop battery acts as the cmos battery.
完成的
All modern computers have a CMOS battery. On some Toshibas it is soldered on, making it impossible for the user to replace. But I'm having a really hard time getting information on the CMOS (or "RTC") battery for this particular laptop. You put "P55W" as the model number. Is there another number after that? Because there are a lot of "P55W" models listed on the Toshiba website.
完成的
@mrjimphelps rethink this "All modern computers have a CMOS battery". Toshiba's are actually known for no longer having a CMOS battery. The BIOS settings are now stored in non-volatile memory, instead of CMOS RAM. This negates the need for the CMOS battery to remember the settings for the BIOS.
完成的
In my opinion, not having a CMOS battery is a poor design. What will happen if you remove your main battery and the AC adapter? Will that reset your BIOS/UEFI settings?
完成的
@mrjimphelps nobody on here doubts this. Manufacturers are not in the habit of asking consumers what to do. That is the reason for existence of this website.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
slide82iron 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 57
总计 690
