跳转到主内容
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
20 个问题 查看全部
CPU getting really hot and Nvidia GPU turning on without a reason.
Hi all,
I have this laptop for some time now and i have 2 problems with it...
The first is that the CPU gets very hot 55-70 degrees while not even under load (general use like watching youtube) and yes i have used compressed air to blow dust out.
Second is that this laptop has 2 GPU' s one Intel intergrated one and one from Nvidia dedicated for gaming. But the problem is that the Nvidia GPU keeps getting activated while i'm not even gaming causing to fans to go absolutely mental.... because it thinks well the Nvidia GPU is active so the user must be gaming
I hope anyone knows a fix to at least 1 of the problems...
Kind regards,
Niels
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have not mentioned correctly but the exact model is the GS70-6QD Stealth
完成的
添加一条评论
1个答案
It is possible that there is a lot of dust in the computer, causing it to overheat.
这个答案有帮助吗?
得分 0
1条评论:
and yes i have used compressed air to blow dust out. I have cleaned the dust out already, and there was not much dust in it. But thanks for your response anyway
完成的
添加一条评论
添加你的答案
Niels 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 82
