跳转到主内容
The Samsung WF361BVBEWR is a front-load washing machine with a total capacity of 3.6 cubic feet.
Why is my washer making loud noise?
Why does my washer make a loud noise, shake just before it starts spinning? Once it starts spinning it stops and is fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It only does it when it starts to spin, so maybe not bearing?
完成的
添加一条评论
1个答案
最有帮助的答案
Cause 1
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Cause 2
Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing.
Cause 3
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shelley Bauder 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 4,260
