跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 Apple logo stuck/ loop after housing change?
My phone hangs after housing change on the Apple logo, then comes a black screen, with a line, see picture, and this is repeated again and again. Tried to restore the phone in recovery mode on iTunes, unfortunately without success. As soon as the restoration is almost finished and the message about Itunes comes "Please do not break the connection to the phone". Cancels everything by itself, and then it repeats itself all over again. Have checked all Conectoren flex cable, Logicboard mounted in another housing with flex cable again the same procedure? See Image
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
As simple as it seems, a lot can go wrong with a housing swap.
You say you checked all the flexes, by that I assume you mean you inspected them closely to insure there are no tears, even tiny ones. Did you also look at the connectors themselves, both on the flexes and logic board?
It's not quite clear from your question but did you try to use the logic board in another device? The challenge here is that you have so many variables. You need to find a way to start eliminating a few of them. For example, if you have a known-good, working device, start moving over one flex at a time until the device no longer works. You also need to determine if the issue is with the logic board (for example, you may have damaged something when prying off connectors) or with a flex.
The horizontal white line is worrisome.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Robin Neumann 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 210
