跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
132 个问题 查看全部
Pairing failure after LCD shift
I cracked my Apple Watch 2 screen and replaced it with a new on my own. However, after the screen shift, the watch fails pairing to any watch. I have tried it a hundred timed on five different iPhones but it always fails. What might have gone wrong? The display shift was easy and was done without apparent problems. Thankful for input!
Update (06/01/2018)
I read here that the only way to get the watch to work again is to ‘reflash new firmware by ibus 2...’:
http://forum.gsmhosting.com/vbb/f1023/pa...
Can anyone confirm that this is what needs to be done?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
17个答案
最有帮助的答案
I’ve been having a lot of issues with this as well (Series 2 iWatch). Trying to restart the phone and iWatch but to no avail. I think switching out the screen will help but in my situation the old screen was non functional (the display was completely out). I’d thought I try something crazy and it worked! I attached the two ribbons (closest to the digital crown) to the new display, then I attached the last ribbon (furthest from the crown) to the old display. After doing this the watch paired after the first try. Hope this helps some people. It was really frustrating looking for solutions all over the web but this worked like magic.
这个答案有帮助吗?
得分 12
10条评论:
Wow, man.
It really works like a magic. I thought that you are joking but decided to try because I wasted my satturday morning for "dances" with Apple Watch 2 with a new screen. I tried all described above before I tried your method.
Your method worked wor me after the first try.
I'm so grateful.
But its interesting - if I will erase my Apple Watch with new screen connected - will the connection error reappear?
Thanks
完成的
Will this work with any original apple watch series 2 screen or does it have to be the one that came with the device before it was replaced? I have a series 2 watch that was still paired to a device before the screen was replaced so after the repair it worked fine until the device was unpaired and tried to pair it to a new device so I do not have the old original screen available.
完成的
Hi! Only ! with the device before it was replaced.
完成的
John Lee ! Thank you! I did it! How did you come up with that?:))
完成的
keep you old screen in a safe place if you need to repair again in the future
完成的
显示更多的5条评论
添加一条评论
此回答最初是针对另一个问题
Hi.
I have testet a lot around this issue now and finally got it to work.
Here is what I’ve tested:
IOS 11.3, 11.4 and 12 NOGO with new screen.
Switched back to the old screen, was able to pair. Updated watch to 5.0.1 . switch screen and still OK. Factory reset on the watch and still able to Pair. So to all: Upgrade watch before switching screen!
这个答案有帮助吗?
得分 3
4条评论:
Thanks Anders. Does anyone know how to update iWatch (after LCD replacement) without the old screen?
完成的
Would also like to find out if the watch can be updated without the original screen?
完成的
how can you upgrade watch when screen is broken?? Cant see squat!
完成的
@pjmfr
you only need the nfc module from the old broken screen.simply connect this module with the appropriate ribbon cable and the other ribbon cables can be plugged into the new screen. if it is too tricky, you can also remove the nfc module from the defective screen with hot air (100 C), because it is only glued. i was able to remove it quite well with a narrow, sharpened spatula and some hot air of 100 C.
完成的
添加一条评论
此回答最初是针对另一个问题
The same thing happened to me. If you look at the other questions on this forum, you’ll find two other examples of exactly the same problem. Unfortunately no one here seems to have a fix. On another forum I read that the watch has to be reprogrammed using IBUS S2, but this adapter + software costs a fortune (more than 100 USD each for adapter and software).
这个答案有帮助吗?
得分 1
1条评论:
I really wish there was an easier fix for this
完成的
添加一条评论
Martin after I fixed the screen and it would not pair I took it to an Apple store ( innocently not acknowledging I had replaced the screen ) they ? Zapped under limited warranty. Bingo it’s fixed
这个答案有帮助吗?
得分 1
1条评论:
Hi did they replace it or what did they do ?
完成的
添加一条评论
此回答最初是针对另一个问题
yup, same here. watch series 2 4.2.something firmware, ios 11.4 iphone firmware.. seems like thease cases will begin to pop up. Unfortunatley I have had no luck in figuring this out. Some say, that by flashing by ibus s2 could fix the issue but unfortunatley there are no ISPW firmwares for apple watch s2 anymore that are being signed by apple.. so not an option here...
However: IF you attach the original screen, pair the watch and then switch to the new screen the watch will work ( more or less... it won't update to 4.3.x complainig about update that could not be verified and of course if you erease you won't be able to pair again...)
Still hoping this is a bug somewhere... and either ios 12 or watchos 5 will fix it and I'm being positive that apple does not want to screw us all..
Anyway..guys.. would be helpfull if you could try to pair with an Iphone running FW 11.3.xy
这个答案有帮助吗?
得分 1
添加一条评论
you must pair your phone first with the broken screen ,,then replace the broken screen with the new one you purchased,its the only wayalso,, keep your old screen just in case you get a new phone or need to repair again in the future.
这个答案有帮助吗?
得分 1
2条评论:
How it works if old screen is damaged?
完成的
@Gadget Garage
完成的
添加一条评论
此回答最初是针对另一个问题
The exact same thing happened to me! Have you figured out how to solve it? I disassembled my watch again and reconnected the screen just in case it was connected wrong the first time, but it did not help. I am most thankful for help. Right now the watch is useless, which is frustrating considering the expensive replacement LCD.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I’m having these issues also. I’ve done everything correctly but after you for some reason unpair it after the screen repair it will no long pair. I have about 3 now that have done this out of 20 repairs. I know everything is assembled correctly so I don’t not understand.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
Exact same problem and have not resolved it. Went to Apple store and was sent off. They probably won’t fix it but hope something good will come from it.
这个答案有帮助吗?
得分 0
4条评论:
I'm still having the same issue. I actually bought a iBUS s2 to try and flash software back onto the watch but I haven't really had time to play with it yet. So in the mean time i've got 3 watches now with this issue. :(
完成的
Hi. Sorry to say this but as I have already figured out..ibus s2 wont help you unless you have a apple watch signed firmware for the apl watch 2..
完成的
Has Apple sent it back or able to fix it?
完成的
i have ibus too but no firmware... cant buy the MfC DONGLE
完成的
添加一条评论
此回答最初是针对另一个问题
Someone wrote that IOS12 might solve the problem, but I now installed the IOS12 beta 3 and tried to pair the series 2 watch. It did not help a bit - it was exactly the same error message that I have got all of the time since the display shift.
Anyone tried WatchOS 5?
这个答案有帮助吗?
得分 0
2条评论:
Is it still not working?
完成的
Sorry but no progress. I tried again today with the sharp iOS12 (after the Watch OS 5 release) but the pairing problem is still there. However, if just OS5 firmware becomes available for re-flash then all could be solved with iBUS.
完成的
添加一条评论
此回答最初是针对另一个问题
Hi. I have replaced the screen in my Watch 3 LTE, because Apple didn’t wanted to give repair/replace service for it, even willing to pay for it, because I bought it in France, and I live in Spain… They have an european warehouse that serves all countries here, so they could send the replacement to any country, including Spain or France. Well, in the Apple Store of my hometown Valencia, couldn’t do it because the LTE version is not yet being sold in Spain, neither helped the Apple Care phone service. That’s the worldwide service that the biggest company in the planet offers.
So I had no choice but do it myself. The new screen works perfectly, colors, brightness, touch sensor and force touch sensor, all. But the watch does not pain again with the phone, with the same error message from above. Anyone has a solution or a clue of what to do?
这个答案有帮助吗?
得分 0
5条评论:
Any updates to this? I have the exact same problem. Watch was working great with the replacement digitizer/screen until i tried to update to Watch OS 5. Now it won't pair with my phone!
完成的
Any updates?
完成的
Here, i had to place the OLD original screen to sync, it wont pair with the new screen, just the old one!
完成的
What will happen if u cant find the oroginal old screen>
完成的
Many people have this question. Screen broke, replaced the screen, old screen is gone, can’t update watch OS because it won’t pair with iPhone. Is there ANYTHING that can be done??
Can a functioning, original (but not MY original) display be connected to my watch body, pair to my iPhone, update watch OS, then switch to the replacement display as described above and it work? Any thoughts?
完成的
添加一条评论
此回答最初是针对另一个问题
Any news about the previously problem? My old scratched screen doesn’t work at all.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
Hi Guys,
I have picked up that if the screen you are trying to use is not truly an original screen then you will run into this pairing issue. I work at a repair centre in South Africa and I had a few of these Apple Watches come in with this issue after we had replaced the screen. Only when I tested the watch with a new ORIGINAL screen then they would pair it with an iPhone.
这个答案有帮助吗?
得分 0
2条评论:
So that means that if you lost your old screen. Buying a used, cracked original screen from Ebay or whatever will fix the problem with the solutions I mentioned above?
完成的
My new screen is used from another Apple Watch S2 but I have the problem again.
完成的
添加一条评论
此回答最初是针对另一个问题
I also had the problem, that my Apple Watch did not pair, after replacing the screen.
But it was very strange, since the watch did pair at first. Then I was not able to add my credit card via Apple Pay or update to wOS 5.2.1 (from 5.2) and so I unpaired the watch, hoping that it would work once pairing it again.
Unfortunately it would not pair again at all.
So I opened it after reading this thread and figured out, that the GPS modules connector was loose and just fell of the display, when I touched the cable.
So connecting the (not working) display from another watch made it pair and upgrade again but still I am not able to add Apple Pay. I guess that it recognises the GPS module and since it is wOS 5 it works even though it is not the original GPS module. But I think, because it is not properly connected to all three cables of the display the GPS maybe is not able to fix a location which disables the Apple Pay function out of security or licensing reasons.
这个答案有帮助吗?
得分 0
2条评论:
i've read that one needs to get an original apple watch display to use apple pay again. because the gps module or whatever apple play uses is fixed to the original display. so when u swap it, the system wont accept the new display for apple pay..
完成的
Same with my spple watch 4 cracked screen.I mounted new screen from aliexpress.Won’t update.So i reset the watch.Won’t pair at all.I did it 30 or 40 times.So,my watch was under warranty.With the new screen non original,touch ok,screen ok,but no pairing,i went to genius bar,and they,without check if my creen was original or not,they gave me another NEW apple watch
完成的
添加一条评论
此回答最初是针对另一个问题
Can anyone find the solution without original screen?
I’m from India I purchased a cracked US version Series 4 GPS Apple Watch, I replaced with new screen unfortunately yesterday I did erase all contents on my Watch and unpaired it with my iPhone now while pairing it I’m not even any pop up message like pairing failed
How to fix this issue in my county no Apple Pay in this case what is solution to pair it again?
You help is appreciated, Thanks
这个答案有帮助吗?
得分 0
2条评论:
I had the same issue, I don’t know if it’s too late but I’ve posted a workaround that worked for me
完成的
this pairing issue appears when you use LTE screen on GPS version screen or vice versa. Just be sure you use the correct LCD (GPS version lcd are more expensive)
完成的
添加一条评论
此回答最初是针对另一个问题
I had the same issue after replacing the screen of a Series 2 (on WatchOS 5.1.3) : impossible to pair it with my iPhone 7 (iOS 13.3.1).
I have just found an alternate solution, using my old iPhone 6 (on iOS 12.4.5) : it didn’t ask to update the watch for pairing and succeeded to pair on my first try !
I then updated the watch manually, to watchOS 5.3.6, unpair it and pair it to my iPhone 7 successfully !
My theory : an old iOS version can pair a watch with an old watchOS and be used to update the watch.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
Can any find solution
how to pair Apple Watch without original screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martin Berggren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 1,994
