跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Previously Jailbreak iPhone will no longer turn on
Previously Jailbreak iPhone no longer turns on
I believe my iPhone 6 might be bricked. No longer turns on just shows Apple logo and shuts off . force boot /respring didn’t work. Doesn’t even pop up in iTunes. Tired using ireboot same thing with iTunes. I’m here asking what do I need to replace to get it working again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Is this happening with or without the charging cable plugged in?
How long does it stay on the apple logo and is it looping?
Sounds like software needs to be restored to be honest. I'm guessing you tried safe mode for jailbreak if I remember correctly you hold volume up while turning on.
这个答案有帮助吗?
得分 2
添加一条评论
1st Q response : it happens for both. While being charged and no connected at all
2nd Q response : I would it says on for about 10 seconds then shuts off and no loop just starts up displays the apple logo then shuts off.
How do you think I fix the software if it is the problem. . Since the iPhone does not register as connected on iTunes. Should I replace the logic board or what do you think .
Thanks for replying
这个答案有帮助吗?
得分 0
1条评论:
Sounds like a battery problem.
完成的
添加一条评论
添加你的答案
Oscar salas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 43
