跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2523 个问题 查看全部
After replacing battery, iPhone will not connect to WiFi
I replaced battery in my iPhone 5. The replacement process seemed to go smoothly. Now the iPhone seems to work OK except it will not connect to WiFi. I tried power off/on, WiFi off/on, delete the ssid and join that ssid again. Still will no connect to WiFi. Did I break something? Thanks for any ideas.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Also double check your iPhone system date, since that was the problem for me (year reset to 2001 or before). Once I changed to current date, that fixed the Wifi and cellular data immediately. Seems to be a protection feature inside iOS.
这个答案有帮助吗?
得分 6
4条评论:
right on the spot. didn't notice that. cost me my girlfriend's wifi password list :(
完成的
Thank yoooooou! I have Bluetooth back! My date was December 1969 :)
完成的
Yesssss! That was all it was. My date was also defaulted to Dec '69. What a stupid thing for the wifi not to work because of that. What a headache. Thank you so much!
完成的
Thank you! Solved it for me too, much appreciated
完成的
添加一条评论
From the Troubleshooting guide:
Weak or lost wireless connections
You have trouble connecting to a wireless network or your calls are suddenly dropped.
Dirty antenna grounds
If your iPhone has been disassembled before, it's possible that finger oils were left on the grounding locations for the Wi-Fi or Bluetooth antennas. These oils will cause grounding issues for the antennas, which could lead to a weak signal or no connectivity at all. Be sure to clean all grounding points with an electronics cleaning solution before reassembling your iPhone to prevent grounding issues. Follow the display assembly guide to open the phone to access most of the phone's contacts.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert Spitz 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 32
总计 3,216
