跳转到主内容
The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
48 个问题 查看全部
Laptop screen wont turn on but keyboard and razor logo will light up
Is there a way that I can get my laptop screen to work again? The keyboard back lights work and the razor logo on the back of the display works when I turn it on. But I get nothing from the display itself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I am also able to connect a HDMI cable to it and I can get the laptop to display on an external display.
完成的
The touch screen works. This confuses me.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @birdup
What is the actual model of your laptop?
If you flash your torchlight on the panel, can you see anything on it?
Some issues that could be causing this, e.g. like Faulty LCD module / panel, Faulty LVDS Cable, etc
这个答案有帮助吗?
得分 3
1条评论:
@birdup "the razor logo on the back of the display works" means you have a working backlight. The digitizer is separate from your LCD and right now it appears as if you either do not get a signal to the LCD or the LCD screen is just not working. Since the external display works I would go with a new screen
完成的
添加一条评论
添加你的答案
Harrison Reisinger 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 24
总计 7,110
