跳转到主内容
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月6号作为iPad Mini Retina屏版本(现在也做iPad mini 2)的新一代被发布。
61 个问题 查看全部
Replaced digitizer AND home button, works, but touch error on power on
Hi, replaced digitizer and home button on an iPad 3 mini. Home button works fine, digitizer works fines.. Upon power on, get touch_id_issue_notification_title popup notification. Click it, goes away, can use tablet fine. We do not need touch ID. Is there a way to disable this message permanently? I have researched it some and it looks like the touch ID will never work unless Apple themselves replaces the home button (wow). But we do not need Touch ID at all, ever. Just want to remove the message. Turned off everything in touch id settings and still pops up. Any input would be appreciated. OS 11.3. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Unfortunately upon start-up, the device will recognize damage to the home button, or an aftermarket part and feel the need to remind you that the touch ID is disabled. If the message is displaying after you have disabled the touch ID settings, it may not stop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike R 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 239
