跳转到主内容
加入维修社区 - 创建账户
提供洗烘一体机以及叠放式机型的维修指南以及支持。
Washer won't start on Kenmore washer
My Kenmore washer will not start. I checked the lid switch and it's working but nothing works when I use the dial. The dryer works fine. I have a Kenmore model number 417.61712510 combo washer dryer. Any ideas please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
7条评论
Have you checked the water fill valve?
完成的
What problems will the water fill valve cause please?
完成的
Washer won't turn on
完成的
Any updates? I have this problem on the same model
完成的
Any other suggestions? Same problem here
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
这个答案有帮助吗?
得分 1
2条评论:
I have exact same model exact problem is it won’t fill with water but acts like it will cycle through with no water. It locks and unlocks though. I’ve tested both water hoses thoroughly. Nothing is working! If I find a solution I will let you know!!
完成的
Where in the world is the Line fuse located on this washer/dryer combo? I having the same problem today.
完成的
添加一条评论
添加你的答案
Bob Sommers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 35
总计 17,866
