跳转到主内容
The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
112 个问题 查看全部
phone turned off and not turning back on
My phone Huawei P8 Lite was working totally fine but suddenly turned off and now it's not turning back on. phone was not out of charge when it died and now, as I plug in the charger, after a while it gets warmer meaning (i think) battery is still charged but its neither turning on nor showing any screen.
Any help would highly be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
最有帮助的答案
Try to Hard Reset your device by following these steps:
1. Remove the battery and wait for a while
2. Meanwhile, you can remove your SD card as well
3. Plug the battery again
4. Hold the “Volume up” and Power button simultaneously.
5. Select “Factory reset” option by using the Volume up and down keys
6. Validate your option with the power button
If the phone has gone into “hard-freeze”
This can often happen with Android. Simply remove the battery (if applicable) and long press the power button for another 30 seconds.
Reinstall firmware
If nothing else seems to function and you are not able to figure out how to fix a Huawei phone that won’t turn on, then consider reinstalling the firmware.
这个答案有帮助吗?
得分 1
5条评论:
But, the battery is non-removable.
I already tried holding power button for 30 seconds, wasn't helpful.
完成的
same....dont know how to realive it
完成的
Hi my p9 lite switch off when it comes to the Huawei logo
完成的
My phone battery cannot be removed. I already tried holding power button and increase volume button at the same for 30 seconds and it's not working. what else can i do now
完成的
完成的
添加一条评论
My phone can charge but the screen blank
这个答案有帮助吗?
得分 1
1条评论:
Change the screen if not work u have a backlight or data problem
完成的
添加一条评论
添加你的答案
Syed Hamza Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 8,134
