Replaced the fuse but the fuse keep blowing
Same problem here.
Replaced the fuse but the fuse keep blowing. Can't find the broken component.
Where did you get those long flat cables for connecting the lcd panel? There are so much useful!
You need first to part the lcd in order to get those LCD cable to make the work on Logic Board easy for you.
Be gentle when open the LCD to avoid cracking the glass.
Second, test the grounding on both sides of the fuse before plugging the power.
from there, you can find the issue why your fuse keeps blowing ..
Good Luck
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 236
1条评论
alex you've left this question as a comment to another answer. Those will get lost. You do now need to tell us exactly what model your iMac is and which fuse you replaced etc. the more details you can give us the great the chances of a good answer.
由 oldturkey03 完成的
