跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
I7+ touch issues after screen replacement
Hello!
I changed screen on a i7+, worked fine for almost a day when the touch started to be messy.
I tried the old screen and it worked perfectly.
Ordered a few more screens and the same issue is there.
I tried to tape the connector and the flexcable shields just to make sure.
(The screens are not low quality).
The phone is updated to latest version aswell.
Anyone of you still got issues with i7+? And got any solutions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Try reseating the connections with the new screen, and then doing a hard reset. With the iPhone 7, I believe it is sleep/wake button and volume up. Hold until you see the Apple logo.
这个答案有帮助吗?
得分 0
1条评论:
The procedure to hard reset is as goes:
Press volume up, then press volume down, then hold power for 15 seconds. It's weird but it's apparently set like that due to the SOS emergency call feature with the volume keys and the home button does not function until the phone is fully booted up.
完成的
添加一条评论
I have the same issue, original screen works fine but non-Apple screen seem to have an intermittent touch screen issue (unresponsive a couple of times per day, requiring a hard reset to restore touch functionality).
这个答案有帮助吗?
得分 0
1条评论:
I'm going to assume apple is messing around with aftermarket screens touch functionality. I think we still need to put an original screen, restore the phone then put the aftermarket one back on.
I have not confirmed this yet because I have not ran into the issue yet.
完成的
添加一条评论
添加你的答案
MrSir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,356
