跳转到主内容
Repair guides and support for the ZTE n817, also known as the ZTE Quest.
70 个问题 查看全部
How do I install in full detail the magnetic sensor so the GPS Compass
I have a ZTE N817 Quest phone & I'm trying to get the magnetic sensor(s) so that the GPS Compass (as well as any other resources I haven't tried so far) will function; however, I'd need EXTREMELY EXPLICIT instructions on what to do to accomplish this task.
Also, for some reason when I make a call on the phone & wish to end it, I've tried pressing END at the bottom of the screen but that doesn't seem to work. I contacted my customer service area & was told to simply press the lower button on the right side of the phone - why shouldn't the END command on the unit function? Is there some way to enable it?
Another question concerns the sensitivity of the unit: As I'm speaking with the phone against my face, it seems that I'm inadvertently pressing keys so I hear numerous beeps. I was again told to press that same button lightly & that would alleviate the sensitivity. When I tried that, of curse, I disconnected the call so there must be something wrong somewhere!
I'd greatly appreciate someone's help with these issues. Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It sounds like either you have a defective touch screen or a case with improperly placed natural magnets (i.e. if it has a magnetic cover).
Natural magnets will interfere with your screen and create a dead spot. Are you wearing magnetic ear rings or have a case on the phone with magnets?
这个答案有帮助吗?
得分 2
1条评论:
Dear SW:
Thank you for your swift answer; however, no I don't wear magnetic earrings or have a case on the phone (although eventually I'd like to have a case for it). I suppose I'll have to call ZTE about the issues & get it
"straight from the horse's mouth" so to speak but thank you again. brbh
完成的
添加一条评论
添加你的答案
Barbara Ruth Blacher-Hecht 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 102
