跳转到主内容
加入维修社区 - 创建账户
Startup problem: grey screen
One morning I tried to startup my Powerbook G4:
I had used "startup sound control", but this time i heard the startup sound and knew this was a bad sign.
When I plug in the power adapter, the light is green at first an then goes orange.
As I tried to start, I heard the sound of ejecting the CD (as usual)
Then the startup sound, and then the screen goes grey...
then nothing more happened...
(by the way, the fan is working...)
I tried to:
- reset pram
- reset vram
- start from startup disc (apple came on the sreen, then the turning wheel, but then the wheel froze and nothing happened anymore..., the same with the hardware check...)
- startup in firewire target mode, single user mode...
- startup in open firmware, worked, but I didn't know what to do there... = )
Thanks for your help!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Boot up from your system installation disk (hold down the "C" key with your DVD inserted, go to the second page pull down menu to Utilities -> Disk Utility and see if the drive can be repaired. If no drive shows up, you'll need to replace it.
这个答案有帮助吗?
得分 1
6条评论:
If it won't start from the original system disk, you'll have to experiment some. Disconnect the hard drive and try starting only from the DVD. Pull both RAM sticks and insert just one, try it in both slots. Next do the other stick.
完成的
thank you!
as I disconnected the hard drive, the computer booted successfully from the system installation cd.
but honestly, I don't know what to do now...
shall I replace the hard disc??
I replaced half a year ago...
完成的
Well if it doesn't start with the hard drive connected and does start when it's disconnected, this is a no brainer. Replace the hard drive.
完成的
I already tried to boot from the system installation disk, but the screen froze, when the turning wheel indicated, that the system was starting...
anyway, I replaced the hard disk half a year ago...
(I put in a new one from the apple shop, because the other one was broken...)
完成的
Try it again, EXACTLY the way I stated. If it won't start this way, you're in trouble. Is this the original system installation disk or a retail disk?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
sigeiger 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 2,323
