跳转到主内容
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
20 个问题 查看全部
How factory reset with Disk
I'm not too fan of This devices i'm a little lost i wanna delete everything i have the disk just don't how to reset it command + R doesn't work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Just a quick note: Command + R only works with OS X 10.7, 10.8, and 10.9. Versions of OS X prior to 10.7 will require the use of a start up install disk.
If you have 2009 model then you should have a Recovery partition in it if it was installed correctly. If you have tried holding down the Command and R keys while restarting and it does not go to the recovery partition, then something is wrong.
Try restarting by holding down the Option key. If there is a Recovery partition, it will show up then.
这个答案有帮助吗?
得分 1
2条评论:
Model is A1224 i believe is from 2007- 2009
完成的
it give me option thank you
完成的
添加一条评论
添加你的答案
alexander galindo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 190
