跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
My iMac won't recognize an external hard drive, but 3 other macs will.
I just bought a 3TB Toshiba external hard drive, and when formatting for mac it on my iMac it was getting an error when I named the drive in Disk Utility. I brought the drive to work and formatted it there (leaving it as untitled allowed it to be formatted).
After working on it all day when I brought it home to my iMac it was no longer showing up in Disk Utility. The light turns on and it sounds to be working. I plugged it into my laptop and it shows up right away.
I believe I might have done something to mess it up just on my personal computer that isn't recognizing it anymore. I hope this makes sense.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What is the drive's connection: USB-A or USB-C or Thunderbolt?
Also, what are your other systems? Mac's or something else and the OS version.
完成的
USB-A I formatted the drive on an iMac running Sierra 10.12.6, and it works on my macbook pro running the same. The iMac it's not working on is also the same.
I am worried something must have happened the first time I tried to format it at home, and now it won't show up at all.
完成的
添加一条评论
1个答案
最有帮助的答案
I don't see your formatting as being the issue as all your systems are the same MacOS.
I'm thinking you have a power type of issue with your system. Are you using the same USB cable? If you are you'll need to get a USB power meter to test across your different systems. IFIXIT offers one but it's out of stock: USB Mini Voltmeter.
Using it you should be able to compare the voltage and current draw between your systems. Let us know what you find.
USB Mini Voltmeter to test chargers and charging functionality.图片
产品
USB Mini Voltmeter
$9.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
brittany metz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 264
