Lower memory slot failure.
Hi! Does anybody know the cause of lower memory slot failure (PowerBook g4 A1095)?
One man said it because the north bridge burning and he can replace it with new one .... Any ideas? Thank you!
I have found on some of these "bad slot machines" that a lesser RAM chip will work when the higher ones will not. I've been able to install 512 k chips in slots that no longer will take the 1 GB chips and its worked fine. Other just won't take anything. It's worth a try if you have the old original chips lying around.
这个答案有帮助吗?
I tried 256 Mb DRR from my old hp (unfortunately i haven't got the original chip) and no result
Did you try the HP RAM in both slots to see if it works at all?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 2,187
3条评论
Do you want to know the cause or the work around? The last three letters of your serial number will tell us your exact machine. What RAM chips do you have for this machine?
由 mayer 完成的
I have to chips Hynix DDR 333 1G. But my powerbook don't recognize the lower memory slot. It's widely known problem. So I have 1G as a result. ;-(
由 leon 完成的
PC2700U .... from about this mac
由 leon 完成的
