跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
20 个问题 查看全部
Transferring home button to new digitizer
I just got a new digitizer for a smashed iPad Air, and I noticed that the home button is kind of sunken, and seems to be missing the Hall effect circuitry. Is there a simple fix for this, or do I have to transfer my original home button over? How do I do that? I haven't been able to find any good documentation on how to remove the button and bracket and glue it on. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You've been probably supplied an incomplete replacement missing something, maybe the metal pin between button and switch. You can remove and transfer the original with a hot air station, it's kept in place just by biadhesive.
这个答案有帮助吗?
得分 2
2条评论:
What kind of adhesive should I use to glue it back down?
完成的
If done quickly at right temperature with surfaces clean from dust you might be able to just reuse and reglue in place the original without any addition. Otherwise a good quality biadhesive (Tesa just to name one) will be the right choice. Avoid stiff adhesives like cyanoacrylates..they tend to break after a while.
完成的
添加一条评论
添加你的答案
da stumer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 99
