跳转到主内容
The 2013 revamp of the desktop Mac series known as the Mac Pro.
117 个问题 查看全部
No serial number under About This Mac post swapping the CPU.
Late 2013 MacPro with CPU, RAM, and SSD upgrades. Not my main machine. Just realized that the serial number does not show up. Other than this, the machine runs perfectly. Apple Store offered to replace the logic board in order to be able to use their serialization tool. The logic board is the original and is otherwise fine. Any ideas on how to flash the board to reset the serial number? Or how to get the tool? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I'd say take it into a Apple Authorized Service Provider and have them run AST on it. It should, if the serial number hasn't been set, prompt them to serialize the unit. Otherwise, you're likely looking at having to get your hands on the serializer tool. You'd want to locate Blank Board Serializer v 1.1.1 .
这个答案有帮助吗?
得分 0
3条评论:
Thanks so much for the response rholcomb3! Can find Blank Board Serializer v 1.1, but not 1.1.1. All of the posts I've read over the last couple of days state that the 2013 Mac Pro can't be re-serialized with what is on the web. Given the prolonged model run, am sure someone has done this. If you have a link to v1.1.1, feel free to point me there. Am a bit hesitant to try to fix this until someone more competent has posted a working solution.
完成的
...more competent than me that is.
完成的
as I know if serial no is visible - cannot be put again (different)
P.S. To find out if everything ok with serial - try to send iMessage from it - I could not do this having NO SERIAL no in my iMac 2012 - when serialized it - automatically fixed
完成的
添加一条评论
添加你的答案
William Dwyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 611
