跳转到主内容
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
How tight does the cap on the coolant tank have to be?
I replaced the coolant reservoir tank . The cap snaps on ok but you can still turn it very easily. Not tight enough to make a tight seal? Still loosing a half tank of coolant every 2-3 days.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Usually you have to press it down with the heal for your hand and turn it to lock it place. Do not do it when the engine is hot.
这个答案有帮助吗?
得分 3
添加一条评论
So it looks to be just a simple snap cap, if that is the case. Then it is just a press fit until it snaps over the rim. Coolant should be half between cold and hot mark at rest.
If you are using green coolant, most likely. Then look for coolant traces around reservoir, check all hoses and connections for condition and tightness.
Find your water pump and check that there is no fluid leaks around that area. Does the fluid pool under car overnight? I'd assume it was the water pump or a failing hose.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mary Mitchell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,679
