跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
After getting my screen replaced, my phone screen is risen too much
My phone screen got replaced today and the screen isn’t flat when you look at it from the side. Is there any way I could just push the screen in without cracking it again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
yes here i dont know i this is too technical or not but heres what i found: screen-size: 5.5inch (139.7mm)
Resolution:1080 x 1920.
depth:7.3mm (0.29inch)
height:158.2mm (6.23inch)
weight:188g (6.63oz)
width:77.9mm (3.07inch)
这个答案有帮助吗?
得分 0
添加一条评论
I don't think you can push it in without breaking it again. What I would do is go back to where you got the screen fixed, tell them the problem and see if they can fix it. But if you can show me a pic of it from the side I might be able to help you more.
这个答案有帮助吗?
得分 0
3条评论:
I’m sorry I can’t post a picture but I may just be paranoid and think my phone screen is raised too much. Do you know where I could find the measurements for an iPhone?
完成的
HI,
I have the same problem after replaced my screen. The screen doesn't work properly so I ordered replacement screen from iFixit. After I installed iFixit's screen, it also risen too much and I had to press hard on the screen to activate 3D Touch. Do you think the mechanist broke my phone?
完成的
No. Your phone is fine. Your screen is aftermarket not Original.
完成的
添加一条评论
It's most likely a aftermarket part that is why it is a little thicker than the orignal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
BTSGarbage 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 35
总计 472
