After getting my screen replaced, my phone screen is risen too much
My phone screen got replaced today and the screen isn’t flat when you look at it from the side. Is there any way I could just push the screen in without cracking it again?
yes here i dont know i this is too technical or not but heres what i found: screen-size: 5.5inch (139.7mm)
Resolution:1080 x 1920.
depth:7.3mm (0.29inch)
height:158.2mm (6.23inch)
weight:188g (6.63oz)
width:77.9mm (3.07inch)
这个答案有帮助吗?
I don't think you can push it in without breaking it again. What I would do is go back to where you got the screen fixed, tell them the problem and see if they can fix it. But if you can show me a pic of it from the side I might be able to help you more.
这个答案有帮助吗?
I’m sorry I can’t post a picture but I may just be paranoid and think my phone screen is raised too much. Do you know where I could find the measurements for an iPhone?
HI,
I have the same problem after replaced my screen. The screen doesn't work properly so I ordered replacement screen from iFixit. After I installed iFixit's screen, it also risen too much and I had to press hard on the screen to activate 3D Touch. Do you think the mechanist broke my phone?
No. Your phone is fine. Your screen is aftermarket not Original.
It's most likely a aftermarket part that is why it is a little thicker than the orignal.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 26
总计 456
