My bosch doesnt dry my dishes snd leaves a funny stale odor
My Bosch dishwasher always leaves my dishes wet after the initial wash cycler and it always has a funny stale odor what can I do
I would first try a good cleaning. Here's a video on doing that. Next mabe your drain hoses are siphoning back into the washer. https://www.consumerreports.org/video/vi...
UPDATE
REMOVING ODORS IN YOUR DISHWASHER
这个答案有帮助吗?
drain hose is not setup correctly where it meets the plumbing and to properly dry needs to be set to "auto" and have sanitize turned on .. rinse aid is also a must
这个答案有帮助吗?
I too have a bad fish smell coming from inside my bosch 300 series dishwasher. The smell was there from the very first wash. I tried all the remedies and so far the smell persists. to make a long story short here is what I think is happening. It could be that bosch has coated its stainless with a fish oil to help prevent corrosion. under normal washing temperatures, there is no smell relesed from the coating. This dishwasher has no drying element. what it does is it supper heats its final rinse so hot that it drys quicker. I think its this final rinse that releases the smell from the coating. Some units have less of this fish oil than others.
Anyways I wish I lower the temperature of the final rinse.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 6,378
7条评论
I have a brand new dishwasher and noticed this the very first time I used it and every time since. It is quiet and cleans very well (although the cycle is longer than I expected). My 12-year old dishwasher did not smell. My Bosch has a stainless steel lining and the old one was just plastic,
由 M Farrell 完成的
I also have this issue, and have attributed it to the stainless steel liner. We have city water, although we live in a rural area. I've tried different tablets and keep the rinse aid full. I also feel it doesn't dry my dishes as well as my old Maytag. It's the Bosch 800 series.
由 Katherine Gillett 完成的
We also have a problem with the Bosch dishwasher
.at times even a 3 hour cycle does not wash clean. Does not dry. The biggest problem we are having is the bad smell. Filter is cleaned. We are using this machine for 6.months and scullery is smelling..wat can be done
由 kalidinreena 完成的
ok I mistakenly posted this in the answer column
I am experiencing the same fishy smell problem with my bosch dishwasher. the smell started from the very first wash. I tried all the remedies and so far the smell persists. to make a long story short here is what I think is happening. It could be that bosch has coated its stainless with a fish oil to help prevent corrosion. under normal washing temperatures, there is no smell released from the coating. This dishwasher has no drying element. what it does is it supper heats its final rinse so hot that it drys quicker. I think its this final rinse that releases the smell from the coating. Some units have less of this fish oil than others.
由 Lorna J Garside 完成的
I also have the same problem i have tried everything Vinegar,baking soda,etc.etc. Still the same smrll persists and it is the stainless in the dishwasher that holds the smell What to do
由 tinacarbone599 完成的
显示更多的2条评论
