iMac screen discolored (smudgy)
Hi,
I bought a used 2007 mod. iMac 24" 2.8Ghz. Now I wonder if there is something wrong with the screen. When I start it up I see areas with yellowish discolored areas and I can see icons and some text shining through at the bottom of the screen, but not icons from the dock. When it is up and running, if I change the background to white I can see the discolored areas more clearly. I have an older 20" white iMac Intel and it does not have the discolored areas. Is this normal and is there a way I can fix this without having to replace the LCD?
Here is a link to a couple of pictures:
7条评论
Can you post a picture of this?
由 rab777hp 完成的
Could it be burn in? I've never seen that on an LCD but it sure sounds like it. Ralph
由 rj713 完成的
It'd be pretty hard to get a burn like that on an LCD as you say. If it is a burn, must also be some problem with the inverter or something, that thing shouldn't be getting that much juice!
由 rab777hp 完成的
Looking at the pictures I would say that's definitely not burn in. Ralph
由 rj713 完成的
But is it normal? And if not is there anything to do about it? My white iMac 20" is not like this.
由 asle 完成的
显示更多的2条评论
