跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
555 个问题 查看全部
Craftsman LT2000 won't start
Sometimes it will start but, most times we have to jump it. The engine engages because you can see it turn. Sometimes manaly turning it helps it start. The battery is new, all electrical has been checked. Fuel line and carburetor are clear.
It is like the battery is discharging between uses. We have replaced the battery twice and still have to jump it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
@kbp1 if it starts with a jump start all the time, then you are having issues with either the battery circuit or the charging circuit. My guess would be charging, since you said you've already replaced the battery. Once your mower is running use a multimeter on the battery cables and check the voltage. Let us know what you find. Your mower (if you have a model number please supply it to us) will likely have an external regulator which receives AC current from the stator under the flywheel. The regulator changes the current to DC so the battery can use it. A basic multimeter can help with the tests
这个答案有帮助吗?
得分 1
1条评论:
Thanks. I'll keep you updated.
完成的
添加一条评论
添加你的答案
Kathy Parenti 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 30
总计 1,826
