跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Laptop shuts down when disconnected from power at 60%
My mbp suddenly started shutting down around 51 to 61% battery when it is not connected to the power cord. The battery status shows that I need to service the battery, but it is no longer under warranty.
I've downloaded Coconut Battery to see my battery's condition, but I'm unsure what to make of it. I've downloaded Python Launder to run an application at log-in, but I get an error on the code I found online. The computer runs well when it's connected but I'm hoping to find a fix because I can't have it conneced all the time.
I've tried doing an SMC reset, but that did not fix the problem either. Any help would be greatly appreciated!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@bobneedshelp
Design Capacity is listed by Coconut battery at 18.9%. For something from 2014, it should be in at least the 80%s. This is indicative of a failed battery.
If you fix it yourself, it is $50-$60 for the battery. Please note, that some disassembly is required, and the battery is glued down to the underside of the palm rest.
Here is the teardown guide if you need it.
MacBook Pro 13" Retina Display Mid 2014
MacBook Pro 13" Retina 显示屏 2014年中期 电池更换
这个答案有帮助吗?
得分 3
添加一条评论
I believe you have a bad battery. You could try sending it to Apple or buying a new one online or in stores, but other than that I’m not sure how to help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bob Ray Delgago 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 148
