跳转到主内容
加入维修社区 - 创建账户
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Washer doesn't agitate, but fills & spins.
My washer fills according to the set water level. Not agitate & after a while, drains & spins. This cycle goes on couple of times until the dial comes to the " off" position. I hear the sound of the timer and a click time to time. No humming in the motor in between. Can anyone help me to identify the problem. Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Thank you so much for your advice. I disassembled agitator and that gear case. All the parts looked fairly good. So I reassembled and add new gearcase oil. My washer started working again.
完成的
Great! Not sure how much wear it got. They usually don't need added oil, keep an eye on it, watch for oil on clothes. The agitator kits are fairly inexpensive.
完成的
I have this same issue. My kenmore is a top loader but does not have the agitator in the middle but it does agitate still. Some of my clothes had oil in it coming out of the wash this weekend and I couldn’t figure out why. Would these helpful this work for my washer to?
完成的
maybe there are alot of possibilities,can't guess
完成的
添加一条评论
1个答案
已选择的解决方案
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Udith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 46
总计 26,199
