跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 个问题 查看全部
What size Hard Drive do I replace the existing one with.
Can you tell me what size or type of drive I need to replace what I have. That would be greatly appreciated.
If you could point me to a cheap one on Amazon the is around 256 GB that would be very helpful.
It would go into my 21.5" iMac that is around 2013 or 14.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Here are the specs for your Mac: https://everymac.com/systems/apple/imac/...
Given that you are looking for a "cheap" one on Amazon, I'm going to assume you are not looking to replace a Fusion Drive setup.
Essentially, you want a 2.5" drive with a SATA III 6 Gb/s connection. So you can search wherever you want for the best deal. I've provided a couple of examples below.
Cheap Option: For a regular 250GB HDD: https://www.amazon.com/250GB-Inchs-Drive...
Performance Option: If you want to spend a little more money for a 250GB SSD (recommended): https://www.amazon.com/dp/B0764WCXCV/ref...
Use this iFixit Repair Guide to help with the replacement: iMac Intel 21.5" EMC 2638 Hard Drive Replacement
这个答案有帮助吗?
得分 1
添加一条评论
If you are going to be opening up that computer it would be well worth it to replace the existing hard drive with a solid state drive! Just make sure you have all of the pieces to do so: SSD, and adhesive strips. https://smile.amazon.com/Crucial-MX500-2...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 164
