跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
Can I move the factory-installed HD to the optical drive bay?
iMac Intel 20" 2210
I want to upgrade from the stock configuration to 1 SSD and 1 HD.
The current drives are stock - the HD is an Intel ICH8-M AHCI; the optical is a Matshita UJ-875 (ATAPI interface). To get the best speed from the new SSD, I am thinking of replacing the HD with the SSD, and then (if possible) moving the HD to the current optical drive bay. Is this possible? Will there be a performance problem with the HD due to the optical drive's interface? Should I be thinking of a different approach?
Thanks,
Wes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Here;s an optical bay hard drive adapter: [关联产品丢失或禁用: IF107-079]
I've had fewer problems just putting the replacement hard drive in the bay and leaving the original drive in place.
Here's how to do it: iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the help!
完成的
添加一条评论
Reopening an old thread here.
I was just gifted a 2008 24" 2.8 iMac with 6gb RAM. It works great for my needs (internet, Word processing, light photo editing), but I have a 120GB SSD from an old PC that I would like to swap into the main drive slot, then add a 1TB drive for storage in the Optical Drive slot.
In hte product description, it reds you can swap up to a 1TB drive. Is this true? It will not accept a 2TB 2.5" drive? Is this a limitation of the PATA connection?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wb5876 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,261
