跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Testing with different batteries
I have an iP5 not charging at all. I wanted to try using the battery from one of my other broke iPhones to see if its the batter or the charging circuit. I don't to completely install the battery, just plug it into the iP5 and see if it charges. Basically, does any other iPhone have the same plug as the iP5?
Or is there some other way to test the iP5? I have cleaned the charging port and contacts. When I plug it in (various combos of chargers and cords) I get the white outlined battery with the red lines at the bottom for 10 seconds. I leave it plugged in and nothing happens. If I move the cord a little I get the lightning bolt and charging cable icon. indicating that the cord has actually came off the charging contacts.
I was planning on ordering a battery anyway, I just wanted to trouble shoot a little more to see if I need to order anything else.
...Thanks Ralph
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If moving the cord a little makes it charge, you're problem may be with the charge port. It's not difficult to replace. I would order it at the same time as the battery as those are the two most common charging failure points. If that doesn't solve the issue, then you likely have an issue with the charge circuit on the logic board, which requires a micro-soldering repair and is not DIY.
The iPhone 5 battery FPC connector is unique.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ralph Goldacker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 38
