跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Why won't my washer fill with water, wash and enter the rinse cycle?
My washer stopped adding water to the machine yesterday after a load was finished. When I attempted to start another load, it would not begin by adding water despite what area I added it in. I attempted to add water to the machine to problem solve the issue; however the water will only spin out. It will not wash or enter a rinse cycle. No agitation occurs.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
REF: https://applianceassistant.com/ServiceMa...
The link above is your service manual. If you are receiving an error code, you can reference the meanings of the codes starting on Page 6-1 and start troubleshooting from there.
Then go to Page 3-16, with the "Washer won't fill, rinse or agitate; washer stops" troubleshooting section. Work through each question to make sure the basics are covered.
Then, I would start testing the components. Start with the lid lock sensor (Page 5-3), then try the water inlet/dispenser valve assembly (Page 5-1). After this, I would go to Page 6-10, and perform the TEST #2 Log Valve.
If all these tests pass, go to the Diagnostic Guide on Page 6-4, and start working from there and systematically work through the operation to find where the fault lies.
Once you get the washer to start filling, then you can troubleshoot the wash/agitation, but most likely, it isn't washing/agitating because there isn't enough water to start the wash cycle, but I would expect that you would see an error code - specifically "LF" for taking too long to fill.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gregory King 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 7,256
