跳转到主内容
Why won't my EP650 Headsets link via Bluetooth anymore?
My EP650's have suddenly stopped linking by Bluetooth to my iPhone. Their indicator LED's flash red and blue. Headsets are fully charged as confirmed by solid blue light. My other devices are linking perfectly so I don't think it's an iPhone issue. Thanks in advance to anyone who can suggest a solution.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Do you still have waranty on your headset?
You might be able to get a replacement one, as it seems the headset itself is failing
完成的
添加一条评论
1个答案
已选择的解决方案
Flashing red and blue is a common indicator that the phone forgot pairing information, and it is in pairing mode.
On the iphone, go to Settings --> Bluetooth
If the headphones are listed, click the "i", and select "Forget the device".
Now, while the headphones are flashing red and blue, on the iPhone side, you should see your headphones listed again under "Other Devices".
Simply tap the name of the headphones to pair it again.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, SW! Your solution solved the problem... Much appreciated.
完成的
添加一条评论
添加你的答案
Rick Cowan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,135
